A Reef Scene
I'm trying to speakers for a diy center channel. The speakers I'm want to use for the center are, Dayton RS1805-8 or the Aurum Cantus AC-180 F1. As far as the tweeter I wanted to use a Morel DSM-30. I just don't know which crossover to use. Are these a good choice or is there a beter option? And can It be bi-wired?
t3031999
I haven't ever heard the aurum cantus driver and has limited info about it.
If I were building a center with the dayton reference woofers, I would probably use a smaller one, like the 6" or even the 5". The 6" is surprisingly slightly more sensitive than the 7". First of all I would pick a smaller driver because midrange, especially the vocal range is generally better reproduced by a driver smaller than 7". And also the dayton reference woofers have nasty break-up at a fairly low register so you either need a high order crossover (3rd or 4th) or you need a incredibly low crossover point.
Now I prefer low crossover points because I feel they image better, but I still don't like being limited by the woofer.
For the tweeter, I haven't heard that particular morel tweeter. but if I were going to spend $66 on one, I would probably instead go all out and spend $87 for a Scan Speak 2905-9500.
This is in my opinion (and in several others) the best tweeter for the money.
Off the top of my head (i.e. with out any calculations) I would probably go for 2 dayton 6" reference woofers in parallel and the Scan-speak tweeter in a ported box of about 1 cu. ft. volume.
Now 2 of those woofers will be slightly more sensitive than the tweeter so you can either tweak that in the crossover, box, or just enjoy the extra bass/mid-range.
For the crossover I would probably go 2nd order (for cost) or 4th order at between 2kHz and 2.5kHz
2nd order is cheaper, but you may still hear woofer break-up, and you need to wire the tweeter in reverse polarity.
4th order would elimate any woofer break-up and would make any driver misalignment problems minor.
About the biwiring questions, all you would have to do is have biwire binding posts on the box, and connect the tweeter to one pair, woofers to another.
Bi-wiring (2 pairs of wires) is pretty much worthless and can actually make things worse.
Bi-amping (2 pairs of wires running from separate amps) can be used, but this center won't require enough power to need it. It can only handle about 120ish watts music, 80 watts rms test tone. So I wouldn't recommend bi-amping.
Anyway I'm pretty much rambling at this point, so i'll stop.
PS. This speaker design may have lower a fairly low impedence depending on the crossover design. So you may have to play with it to get it to the impedence you want. Although raising the impedence helps out amps, it decreases the sensitivity of the speaker which doesn't help amps.
See, here I am rambling again...
A Reef Scene
Thanks for the info. Where can I buy that kind of crossover?
Swerd
Swerd
You can't buy that kind of crossover. You should build your own, but you don't have to design your own. Any combination of speaker drivers and cabinet requires a custom made crossover. Don't spend good money on those drivers and blow it by using an off-the-shelf crossover that was not intended for your application. If you have never assembled and soldered electronic components, fear not. Its easier than you think.
There are lots of good designs available on the internet combining one of the Dayton RS drivers with the Dayton RS tweeter (it is also shielded). They all include a custom designed crossover. If you plan to spend the money for the Morel DSM-30 (also a very good tweeter by the way) then you should definitely consider the RS tweeter. I'm not aware of any designs that use a RS woofer with that Morel tweeter. You might make your life easier by using a design with the RS tweeter.
t3031999's comments about using a smaller woofer such as the RS 5" are a good idea. Most center channel speakers are used in the "small" mode in HTs. They are for voice and dialog, not bass performance.
Swerd
Swerd
Here are a few sites with various designs using Dayton RS drivers
Jon Marsh - has a number of designs using Dayton RS drivers:
http://www.htguide.com/forum/forumdisplay.php4?f=6
http://www.htguide.com/forum/showthread.php4?t=11321
Dave Brown
http://users.d-web.com/dbrown/speakers/speakers.htm
Dr. K MTM design at the Parts Express dot com project showcase
Paul O'Neil
http://home.stx.rr.com/poneal/index.html?Page=Speakers
Roman Bednarek
http://www.rjbaudio.com/RS180MTM/rs180-rs28-mtm.html
http://www.eldamar.net/audio/rs150mtm/
