Reorx
This is hard to phrase so bare/bear/beer with me. hmm beer.
Generally Amps rough distortion range are .005 to .1
At what point can distortion be heard at normal reference levels? (non subs)
Also, is distortion additive, multiplitive?
amp - .05
receiv-.05
total - .1? .25? .0025?
Does distortion vs spl increase exponentially?
I know that this will probably depend on the speaker brand, and the receiver.
Now, pertaining to subwoofers...
Is distortion just as noticeble?
Someone once told me that subs pretty much are made to output distortion, so you can use a amp with high distortion and wont notice a difference...
Thoughts?
Reorx
Reorx said:
That is music dependent. A simple flute would be more sensitive to detect than an orchestra. But, I would not worry about .1%, or even more at times. There are some references around on this.
amp - .05
receiv-.05
Well, that stand alone amp would be connected to a pre amp out, so we would need to know that distortion. But, for this, let's assume it is .05. You would add to that .05, .05% of that .05= .0525%, or so.
No, it is not as the hearing is much less sensitive in the low region for detection. Subs are rated in reviews up to 10% distortion.
Thoughts?
Reorx
No, subs are not designed to have high distortion. Other factors are at play. Velodyne subs use servo controls to keep distortion very low:D
