SONOFA.....! I'm relieved and pi$$ed at the same time.
The girls are out and I found some time to do some further investigation. Just to backtrack a bit, the other day, I disconnected the CD players and tried an old DVD player to see if that was the root of the problem. I didn't think it would be and I was right. I got the same distortion. This evening, I decided to change the inputs for the CD player - yeah, I was grasping at straws. Anyway, after I changed the CD interconnects to "disc", I selected that input on the front panel and then noticed that the tone control button was engaged and the treble knob was
turned all the way up! All along, it seemed to me that the distortion seemed to be in the higher frequencies, but I believe my hearing is degraded in the upper ranges, so I wasn't sure. I turned the treble back to the middle position and disengaged the tone control.
I held my breath and tried the same Miserere CD that I was playing when I first noticed the distortion. Miraculously, the distortion was gone! I had never heard the distortion while listening to the FM tuner - at least I hadn't noticed it before. Could that be because of the limited frequency range of FM - relative to CD, that is?
I know I'll never find out who had messed with the tone controls. My wife and daughter wouldn't have touched them, but we have several small nieces and nephews who visit frequently. I suspect one of them of playing with buttons.
I'll try a couple more CD's before I put this issue to bed, but I think I'm good to go.
