DISH Winegard Pathway X2 Portable Satellite Dish Antenna
admin
Audioholics Robot
Staff member
DISH has a new product, the Winegard Pathway X2 portable satellite dish antenna. There are a couple really great things about this. First, it's automatically self-pointing and you can connect it to two HD solo receivers. That means you can set it up at a tailgating party and use dual satellite receivers. On top of that, the antenna can track with either the Eastern or Western satellite arcs. So if you're stuck parked next to a building that blocks your view of the western arc, you can switch over to the eastern arc and pick up all your channels.
<iframe width="640" height="480" src="//www.youtube-nocookie.com/embed/BhaEV7ewtm8" frameborder="0" allowfullscreen></iframe>
Check out our coverage of the DISH Winegard Pathway X2 Portable Satellite Dish Antenna
