Dish Sat DVR-942 HMDI to Panasonic Plasma
meisteri
Ran a HDMI Cable from my new Dish Network receiver DVR-942 to my Panasonic Plasma HDMI input with internal speakers. I have great video. I am however not getting any audio thru the plasma internal speakers. I have audio output cables going from the tv to my receiver and I am getting sound thru this connection. I have tried different audio settings in the tv audio menu :mad: to get the tv speakers going and have had no luck. Any suggestions would be helpful. Thanks.
MDS
A couple of thoughts (that may or may not be useful :))
1. Many TVs disable the audio outs if the internal speakers are on. Your problem sounds like the opposite; ie the audio outs are enabled and it may have automatically disabled the internal speakers. You could try disconnecting the cables from the audio outs of the TV and then using the TV menu to enable the internal speakers.
2. It's possible that you need to make an additional analog audio connection to the plasma, even though you are using the hdmi connection which is capable of carrying both audio and video. I know it sounds counter-intuitive, but I just read the manual for the Sony LCD I am considering and it says you must hookup the L/R analog audio connections when using HDMI. Maybe there is no path to the DACS when using the HDMI connection so it requires the additional analog audio connection. Check the Plasma manual and see if something similar is going on there.
meisteri
Yahoo
Followed your advice and now its working perfectly. Thanks. :)
