I dont know why people would say not to use WD40, I learned about it as a contact cleaner when I worked a Emod mechanical, and when controls had moisture in them they had us spray them down with wd 40 and power them back up the next day, never failed...
Im not saying to douse it, just spray a little on a rag and wipe them off... If you have a can I wouldnt go buy a can just for that but I know a lot of people have a can in the garage so its an easy fix... Im sure alchahol will work even windex or a damp rag as long as you dont leave anything wet...
I wouldnt over think it...
But for people to say not to use WD40 like it will hurt something isnt correct...
After all its good for everything... I spray it on my bait, its the best fish attractant Ive ever used... Spray some in a pond and see the fish come up to the surface for it..
WD40 stands for Water Displacement #40. The product began from a search for a rust preventative solvent and degreaser to protect missile parts. WD-40 was created in 1953 by three technicians at the San Diego Rocket Chemical Company. Its name comes from the project that was to find a “water displacement” compound. They were successful with the fortieth formulation, thus WD-40. The Corvair Company bought it in bulk to protect their atlas missile parts.
Ken East (one of the original founders) says there is nothing in WD-40 that would hurt you.
When you read the “shower door” part, try it. It’s the first thing that has ever cleaned that spotty shower door. If yours is plastic, it works just as well as glass. It’s a miracle! Then try it on your stove top... Voila! It’s now shinier than it’s ever been. You’ll be amazed.
Here are some of the uses:
1) Protects silver from tarnishing.
2) Removes road tar and grime from cars.
3) Cleans and lubricates guitar strings.
4) Gives floors that ‘just-waxed’ sheen without making it slippery.
5) Keeps flies off cows.
6) Restores and cleans chalkboards.
7) Removes lipstick stains.
8) Loosens stubborn zippers.
9) Untangles jewelry chains.
10) Removes stains from stainless steel sinks.
11) Removes dirt and grime from the barbecue grill.
12) Keeps ceramic and terra cotta garden pots from oxidizing.
13) Removes tomato stains from clothing.
14) Keeps glass shower doors free of water spots.
15) Camouflages scratches in ceramic and marble floors.
16) Keeps scissors working smoothly.
17) Lubricates noisy door hinges on vehicles and doors in homes.
18) It removes black scuff marks from the kitchen floor. Use WD-40 for those nasty tar and scuff marks on flooring. It doesn’t seem to harm the finish and you won’t have to scrub nearly as hard to get them off. Just remember to open some windows if you have a lot of marks.
19) Bug guts will eat away the finish on your car if not removed quickly. Use WD-40!
20) Gives a children’s play gym slide a shine for a super fast slide.
21) Lubricates gear shift and mower deck lever for ease of handling on riding mowers.
22) Rids kids rocking chairs and swings of squeaky noises.
23) Lubricates tracks in sticking home windows and makes them easier to open.
24) Spraying an umbrella stem makes it easier to open and close.
25) Restores and cleans padded leather dashboards in vehicles, as well as vinyl bumpers.
26) Restores and cleans roof racks on vehicles.
27) Lubricates and stops squeaks in electric fans.
28) Lubricates wheel sprockets on tricycles, wagons, and bicycles for easy handling.
29) Lubricates fan belts on washers and dryers and keeps them running smoothly.
30) Keeps rust from forming on saws and saw blades, and other tools.
31) Removes splattered grease on stove.
32) Keeps bathroom mirror from fogging.
33) Lubricates prosthetic limbs.
34) Keeps pigeons off the balcony. (They hate the smell).
35) Removes all traces of duct tape.
36) Folks even spray it on their arms, hands, and knees to relieve arthritis pain.
37) Florida’s favorite use is: “cleans and removes love bugs from grills and bumpers.”
38) The favorite use in the state of New York WD-40 protects the Statue of Liberty from the elements.
39) WD-40 attracts fish. Spray a LITTLE on live bait or lures and you will be catching the big one in no time. Also, it’s a lot cheaper than the chemical attractants that are made for just that purpose. Keep in mind though, using some chemical laced baits or lures for fishing are not allowed in some states.
40) Use it for fire ant bites. It takes the sting away immediately and stops the itch.
41) WD-40 is great for removing crayon from walls. Spray on the mark and wipe with a clean rag.
42) Also, if you’ve discovered that your teenage daughter has washed and dried a tube of lipstick with a load of laundry, saturate the lipstick spots with WD-40 and re-wash. Presto! Lipstick is gone!
43) If you sprayed WD-40 on the distributor cap, it would displace the moisture and allow the car to start.
P.S. The basic ingredient is FISH OIL.
P.P.S. I keep a can of WD-40 in my kitchen cabinet over the stove. It is good for oven burns or any other type of burn. It takes the burned feeling away and heals with NO scarring.
