DirectTV Plus HD DVR not working with receiver
tshark
Hey. So I was able to hook up my friend's DirectTV hd box through my receiver to a tv via HDMI and it worked, but now im at my own place and I have the new Direct TV Plus HD DVR box and it wont work, the receiver recognizes it because when I go in to manually assign the port, it already has it set to CBL/SAT but no sound or picture comes out.
I have a Yamaha RX-V2600. Does anyone know whats the problem? Thanks!
ParadigmDawg
ParadigmDawg
My DT HD DVR comes on Friday so I hope I wont have this problem!
markw
Not all satellite/cable boxes are created equal. Try a little truobleshooting.
Does your box work via HDMI when you connect it directly to the TV? If so, you can always run a toslink/digital coax connection to your receiver to get digital sound.
Then,call your service provider. Tell 'em about your experience with your friends (non-DVR) box. Ask 'em what's up.
With all the different boxes out there they may be your best bet.
FWIW, if you can use component ot may make things a little easier. That can handle up to 1080i if your box can output it. My Motorla cable box can. And, dependig on your TV it may or may not even display 1080i. It may accept it, but it may not display any more than 720.
jimfitz
If you're trying to use HDMI cables, maybe your SAT box is not HDCP compatable.
