Confused!
pank said:
I want to have DirectTV audio in my Bose 321 GS system. I have following configuration:
1) DirectTV input in-built in wall jack(coaxial only, no reciever)
2) Sony VCR (Remote doesn't work)
3) Bose 321 GS Media player
4) TV (Mono not stereo)
I am able to get the DirectTV audio in Bose system through VCR but I don't have remote so that every time I change the channel through the VCR itself , and the sound is not good too.
1) Is there any other way to setup the systems to produce great sound?
2) Is there any digital cable availible in the market which has one end is coaxial and other end is digital or optical ?
3) Which is the best setup to listen surround sound of directTV?
Thanks,
-Pank
Some things need to be cleared up first:
1) You said that you don't have a Direct TV receiver
...without one you won't be able to get Direct TV Audio
(I assume that you want the CD channels). And a VCR won't control SAT channels.
2) You said the cable (coax) was coming from the wall jack...do you have a dish???
I'm thinking that what you have is the cable line...not a SAT line...if that is the case then you have cable not Satellite.
3) For the remote issue...just but a low cost universal remote, like this:
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=182-200
Then you will be able to control the VCR
4) In your second question you can use this:
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=180-970
It will convert the analog audio from the VCR to a digital signal (either optical or digital coax)
We need some more info to help you out, especially regarding the Direct TV issue.
Hope I helped some.
