I have a Yamaha rxa3070 set up with two subs using sub pre-outs 1 and 2 using mono signal. After setting up both subs to the best of my ability with placement, levels, and distance settings to get highest db levels played together, I noticed bass was stronger with just front sub playing switching off second sub in receiver menu, so after much experimenting thinking back sub must be cancelling because of phase issues I turned volume down as far as possible (-60 db ) on rear sub and again played good bass music and switched between one sub and two and the bass level still changed about 3db, less with two subs selected. Im going to assume its because when you select two subs mono it splits signal strength in halve? anybody else notice this?
