Hi, I want to archive a number of cassettes and old vhs tapes. I am petty competent about computers, but a newbie dealing with conversion and restoration. I am going to try to keep costs down, so I'll avoid expensive pro level software. For audio: Nakamichi BX-300 deck, bought used sat idle long time, but seems to work fine, I'm looking at buying a Creative Labs Sound Blaster X-Fi sound card with a front panel breaker box w/RCA inputs, open to suggestions about software for noise filtering, anyone have experience with Audacity (freeware), BIAS soundsoap, or Nero. I see that some people like SoundForge. I assume that the front stereo inputs on a box will result in less interference than the minijack on the soundcard at the rear of the case. I asked Creative tech support how box to card 26 pin ribbon cable is shielded form noise inside the case, but I have to get a reply. For video, my pc is fast, Core2duo e6600, 2 GB Ram, Hauppauge pvr 150 tv tuner pci card, and Premiere elements 3.0. These tapes, both cassette and vhs, are 10-15 years old, kept in pretty dry climate-Los Angeles. The Hauppage card will convert to MPEG, hardware conversion. Will such compressed video be impossible to clean up at all? Do I need to import as AVI or similar or can I work in MPEG? If I have to import as AVI or similar what best convertor-Canopus (pricey), or Pinnacle, Pyro, or other. Thanks in advance!
