what is the difference between dolby pro logic II, dolby digital, and THX?
G Gbiz Audioholic Intern Nov 10, 2005 #1 what is the difference between dolby pro logic II, dolby digital, and THX?
Matt34 Moderator Nov 10, 2005 #2 http://www.dolby.com/consumer/technology/prologic_II.html http://whatis.techtarget.com/definition/0,,sid9_gci214387,00.html http://en.wikipedia.org/wiki/THX
T Tritonman Junior Audioholic Nov 10, 2005 #3 Tons of answers to tons of questions. http://www.hometheaterforum.com/htforum/showthread.php?&postid=651725
j_garcia Audioholic Jedi Nov 10, 2005 #4 Prologic and THX are not formats. PrologicII is a DSP for stereo and surround encoded material and THX is a post process that "helps" theoretically, and can be applied to any digital format, though I don't like the way it sounds so I don't use it. www.thx.com and also www.dts.com
mtrycrafts Seriously, I have no life. Nov 10, 2005 #5 j_garcia said: ...and THX is a post process that "helps" theoretically, and can be applied to any digital format, though I don't like the way it sounds so I don't use it. www.thx.com and also www.dts.com Click to expand... It is also a standardization process to achieve and get closer to what was recorded at the studio.
j_garcia Audioholic Jedi Nov 11, 2005 #6 THX also includes some processing functions that are designed specifically for home theater such as RE-EQ.
