Thanks for the replies so far everyone!
The reason for the long run is that I have 8 displays that are located throughout the house. All of the video sources and displays are routed through a Extron 128 HVA (12 input, 8 output audio/video matrix switcher). This allows me to only use 1 or 2 HDTV tuners throughout the entire house instead of paying an extra $5 per month per box, per room for my satelite service. all of the A/V equipment is controlled with Crestron gear, allowing most of the A/V equipment to remain in the basement where the theater is located. However, I am going to put DVD players in some of the rooms upstairs, and will need to rout the digital audio (coax) from the upstairs DVD players downstairs to the matrix switcher and then back upstairs to the reciever that the audio will be played through. Now that I think about it, this will actually require 2 cables approximately 75' each. one for the run from the DVD player to the matrix switch, and another from the matrix switch back to the receiver.
Am I pushing my luck trying to do this?
If you think it can be done, what cable do you recommend? (I am connecting with RCA style connectors)
If this can not happen with a digital coax, I have found these coax to optic converters
http://www.trianglecables.com/pof-820.html and I gues I could use these to run long fiber optic runs, if they make fiber optic cables with toslink connectors in 75' or longer lengths. Does anyone know where I can get optical TOSLINK cables at least 75 feet long?
Thanks for the input,
DG
