Is there a product out there that can merge 2 Digital Audio Outputs into 1 Digital audio input? My receiver only has 1 Digital Audio input and I was thinking that it would be nice to have both my digital cable box as well as a DVD recorder feed into the receiver.
I have seen splitters (
example) for Digital Audio optical cables so that output can be fed to multiple sources. I'm not sure if this product works in the reverse as well (ie multiple sources to 1 input.
The thought just struck me that this would create problems for the receiver in determining which source to select....
Any thoughts or suggestions?
