Differentiating Factor
saurabh
saurabh
I pretty new to screen types and dont understand them well. Whats are the differences between Plasma, DLP, LCD, CRT. What are their good or bad features and how do you decide between them, given that price is not a factor and are of the same size.
Rob Babcock
Rob Babcock
Moderator
Well, CRT has long been the "Gold Standard." The resolution and color accuracy of a good CRT is still very hard for any other technology to top. But CRT is being replaced, mostly because newer solid state technology is cheaper & more compact, not so much for performance reasons. Pros: Excellent resolution, SOTA color accuracy. Cons: Pricey (at least the large ones), very large and heavy, and you lose brightness over the light of the set. Picture somewhat succeptible to "burning in." Convergance can be an issue.
Plasma- Sleek, sexy & thin. Resolution falls short of CRT, and color isn't as good. IMO plasma falls well short of CRT performance wise and exhibits several problems- false contouring, poor black level, and slow gray scale transition. Most of these areas are improving, however, and the prices are coming down. Pros: Very compact & thin. Trendy, "sexy." Cons: Absolute performance, price is a tad high (but coming down). Very very succeptible to screen "burn in"- game on one at your own risk.
LCD- This uses liquid crystal displays to project a picture. The cost is very low and the color is pretty good. The PJ market is being hotly contested by LCD and DLP. Pros: Price- LCD is pretty economical and very compact. Good resolution & Long life. LCD's have no possibility of burn in. Potential for good performance. Cons: Space between pixels causes a 'screen door effect,' although newer LCD panels exhibit this much less than older models. Somewhat poorer contrast and black levels than newer DLP, and not in the same league as CRT.
DLP- This technology is based on Texas Instruments Digital Light Projection Engine. It uses a small chip covered with micromirrors and a spinning color wheel to project an image. DLP is very compact, very affordable and lightweight. Pros: DLP, like LCD, will never burn in. Resolution is very good, and contrast/black levels is generally better than LCD. Can project a bright picture vs CRT. Cons: The sequential color wheel pattern can cause color separation artifacts, aka "Rainbows", that are very disconcerting to some viewers. Many people can't see the effect at all (myself included) but those who can simply can't live with DLP. Bulb life varies, but can be expensive. Black level better than previous generations of DLP, but still not as good as CRT.
Summary: The technology isn't as important as the implementation, and all can be viable. For smaller TVs, it hard to touch a good ol' CRT. In direct view and RPTVs they can be a good choice, although getting maximum performance usually requires professional calibration. CRT can be extremely expensive if you want a projector, though. Plasma is the hot product right now, but even the best plasmas I've ever seen fall short of the better DLP & CRT sets (although this is partly subjective). IMOHO plasma isn't quite ready for prime time yet, but it's improving. You can also fit a plasma set in places no other TV will fit. To me, LCD doesn't quite get me there, although I'll concede I haven't seen the very latest HD models. I prefer DLP, but I can't see the dreaded "Rainbow Effect"- if you can, you'll never be able to tolerate it.
This is obviously a "TV For Dummies" simplification, but I hope it's useful. I imagine someone will come along soon and say everything I wrote was wrong. :p
saurabh
saurabh
Thanks Rob for a very down to earth post but I have few more queries regarding some terms being used
HDTV
RPTV
Directview TV
BTW whats IMHO or IMO ???
Rob Babcock
Rob Babcock
Moderator
HDTV
RPTV
Directview TV
HDTV= High Definition TV. While there are 18 different HDTV standards, the term is usually used to mean a resolution of 1080i (1080 vertical lines, interlaced) or 780p (780 vertical lines, progressively scanned).
RPTV= Rear projection TV. This is the type of TV where the projector is inside the same box as the screen, projecting the picture onto the back while you view the front. This is what people commonly refer to as a "big screen TV."
Direct View TV= This is your conventional tube television set, the kind you'd have in your bedroom or see in a motel. Until recently, almost all computer monitors where also direct view. Now LCD (called 'flatscreen monitors') has virtually replaced them due to low power consumption, economy and compactness.
IMHO= In My Humble Opinion
IMO= In My Opinion
WTF= What The...well, you can guess! :p :D
BMXTRIX
BMXTRIX
Don't forget that LCD televisions come in two flavors:
Rear projection LCD displays, which are similar to the rear projection DLP displays. They will be shown side-by-side to DLP at your local Best Buy and Sony has some models that look absolutely stunning.
Flat panel LCD displays - Flat panel displays (FPDs) in the LCD variety will be sitting right next to the plasma displays at Best Buy and usually you can't tell right away which is which. Most LCD FPDs are smaller though, running between 13 and 37 inches diagonal. There are a few larger ones, most notably on the consumer side is the Sharp 45" LCD display. If you are going flat panel and don't need something as big as a 42" plasma, then LCD flat panels are the way to go.
IMHO (In my honest opinion) ;) - I would go with rear projection CRT if I had the space to put it in. It looks great and is typically much more cost competitive than any of the newer technologies. It also lasts a long, LONG time. Rear projection DLP & LCD look nice and are a good choice for the money, but the potential for issues I believe is much higher with LCD & DLP RPTVs. There is also the 'bulb' factor. If you have a bulb blow once a year, which is a real possibility in a heavy use home, and new bulbs cost $300.00 - then in 5 years you are paying an extra $1,500.00 for your set on TOP of what you paid initially. Warranties can be good if bulbs are covered.
Then there is the whole world of front projection television... 10 foot screens for under $2,000.... ahhhhhhhhhh ;)
Rob Babcock
Rob Babcock
Moderator
I do have an FPTV-centric point of view. A direct view is fine for my bedroom, but I'll never go back to RPTV for my main rig. NEVER! :p
