superstar
Hi all,
Just when I thought I was already set with the HT room, I've noticed that when switching channels between sdtv, hdtv and playing a dvd, the volume do not exactly match. The DVD seems to be the loudest when played at 60 or 60% (as seen on the Onkyo sr-604) when I switch it to hdtv, I have to turn up the volume to at around 67, and if it's to regular tv, the volume needs to be turned to 75 to get the same loudness as the DVD.
From the cable box I have component and rca cables running to the receiver, from the dvd, I have hdmi to the receiver, I do not use the tv speakers at all, they are turned off. From the receiver part I have already ran the Audiossey (is that the right spelling?) equalizer set up mic.
I did everything that was on the manual and reread it just to make sure I didn't miss a thing, is there a setting that I'm missing?
Thanks in advance for any inputs!
