I have been looking into this, and researching it for you as time permits around the holiday. I guess the b0ttom line is that auto transformers in parallel, which is what your four impedance matching controls will be need to be identical in terms of resistance and inductance. This means they have to be identical auto transformers in terms of the core, turns and wire gauge.
So this means you do actually need to replace all your controls.
