There was some discussion regarding SVS' older and newer Plus series drivers in Craig's SVS/HSU thread and since I didn't want to hijack that thread again (!), I decided to open my own.
I'll post a quote from that thread first.
For those looking at a direct comparison to the SVS ... Here are the numbers on the pb12-plus. One area of interest - it was always said that the "Plus" was about 1.5 to 2 dB lower in SPL than the Ultra. Based on some recent tests, the "new" (12.2) plus delivered about 4 dB more SPL than the old (12.1) Plus, in SPL below 22 Hz ... just something to keep in mind.
Since I have measured both the older dB12.1 and the newer dB12.2 (both subs were 20-39PC+ cylinders), I can give a little bit more accurate info than the generalization above. First of all, we can't just look at the difference at certain frequency. We have to look at the whole range from 20 Hz up to 100 Hz. Below 20 Hz both subs will drop pretty fast in 20 Hz tune, so no point comparing that data, though dB12.2 is a little bit stronger there.
This first graph shows three frequency sweeps. The sweeps went from 100 Hz to 10 Hz and were 45 s long, meaning they would heat up the voice coil real good. These three sweeps were the three highest ones sub could produce without compressing totally. This first one is for the older dB12.1 driver.
And here are the same three highest sweeps for newer dB12.2 driver. Notice how the actual shape of the curve is different. Older driver produces more straight line and then straight drop, when the newer is one much more rounder and extends a little bit deeper.
You can calculate the SPL at different frequencies by yourself, but I already did it and put them in a table. The same table shows also maximum SPL with single sine waves, when THD was max 10%. Notice how the max levels are actually higher at some frequencies with single sine waves than with a long sweep (VC heats up more).
When looking at the table, it's pretty obvious that regarding only max SPL, both drivers are very similar, only 0.5-1 dB differences here and there, but not a constant difference. Only when THD is limited to 10%, differences go larger. Near tuning frequency at 20 Hz and higher at 80 Hz the newer dB12.2 is much more stronger than the older driver. But I highly doubt if anyone could hear this difference with a program material.
So how about Ultra then? It's still the same 1.5-2 dB stronger below 50 Hz than it has always been.
