Difference between subwoofer, s/pdif, & component video cables?
L
latrosicarius
Can someone please tell me what the differences between these cables are?
S/PDIF coax digital video cable
"subwoofer" cable
Component Video cables
They all look the same! Are they really different? Even RCA cables look like they would fit.
Thanks
jaxvon
jaxvon
"subwoofer" cable
Thanks
Yes and no. They all use the same 75-ohm coax cable and RCA connectors, but the component video is comprised of 3 cables instead of one like the others (composite video is identical to the other two). So in essence, yes, they're all the same.
L
latrosicarius
Sorry, when I said Component Video, I meant just one of the three cables... like my Component Video consists of three of those cables that are stuck together.
Ok so thanks, that's all I needed to know. Now I know that I can hook up my subwoofer and s/pdif with cables I already have, rather than buy specific ones.
Thanks!
Thanks!
Precisely. And, that sub cable can be even that red/white interconnect as it doesn't really need to be a 75 ohm cable; however, that 75 ohm will work equally well.:D
BMXTRIX
BMXTRIX
75 ohm cables are 75 ohm cables - marketing and the word 'digital' allows many companies to take advantage of you.
Here's the list:
Composite Video = One 75 ohm cable
S-Video = Two 75 ohm cables bundled in a single casing
Component Video = Three 75 ohm cables
Subwoofer = One 75 ohm cable
Coaxial Digital Audio = One 75 ohm cable
The cable from your cable company to your TV = One 75 ohm cable
VGA Cables = Five 75 ohm cables, plus extra cables, in a single jacket
Stereo Analog Audio = Two 75 ohm cables (most often, audio doesn't require 75 ohm cables!)
The ENDS of cables do not affect what type of cable is in between and adapters that go from one type of end to another are fine to use to get the cable connection you need.
That is, there is no such thing as a RCA cable. RCA is the connector on the END of a cable, and it does not determine the actual cable that is between the two RCA connectors.
Common connector types on the ends of 75 ohm cables:
RCA (most common, and typically color coded to indicate the typcal usage, even though this does NOT change the qualities of the cable) Yellow = Composite, Red/Blue/Green = component. Digital audio is often orange, while analog audio (stereo) is typicallly red & white.
S-Video - Round connector with 4 pins inside
DB15 or D-Sub 15 = The 15-pin connection on a VGA cable
BNC = Typically found on pro gear, it locks onto equipment and can't fall off.
F = The screw on end that you connect an incoming cable line to the back of your TV.
Quite often I will use RG-6 cable to send a subwoofer signal to a wall plate and I will put F-type connectors on both ends, then the wall plate will have a F-type connector on the back side, and a RCA type connector on the front. This way, the cable can lock onto the back side of the plate and never fall off, while I can use standard RCA ended cables to connect my sub.
philh
does that have an increased risk of noise?
JKL1960
Using a wall plate or using RG6?
RG6 makes most shielded cable look pretty lame. I prewired my sub locations with a 3.2ghz rated quad shielded RG6 that is approved for use in sattelite internet installations. Should handle a less than 100hz signal just fine and no noise. While I can install wall plates it is currently long enough to run unbroken from amp to sub.
I have also used the same wire for spdif with zero problems.
markw
Theoretically, yes, but in practice, not that you would ever hear.
You weigh more if you have a quarter in your pocket then when you don't, but can you notice a difference when you walk?
philh
Never mind, for some stupid reason I was thinking CAT 6, and wondered how that would work as a sub cable... I'll return to sleep now, LOL
If and when I have two or more, I can hear it jingle:D Does that count? LOL:D
latrosicarius said:
wow, thanks!
I'm saving this thread lol
Does your moniker have anything to do with medical terms? :p
L
latrosicarius
Nah, it's Latin for "hunter-killer"...
'cept it doesn't quite translate like that,.... more like murderer-assassin (close enough lol)
