Difference between Sony MDR-7506 & V6
Jack Hammer
Jack Hammer
Ratings
201
#1
I've been looking for a pair of headphones under $100. I was following some of the other threads. I'm confused as to the difference between the Sony MDR-7506 and MDR-V6 headphones. Some people said they are essentially the same. But, I noticed the V6 sells for about $30 less than the 7506 does. Why is that? What is different about them? Which is a better headphone/ dollar for value?
Tia
Jeff
WmAx
WmAx
Ratings
1,417
#2
Tia
Jeff
The official replacement part numbers, as provided by Sony, indicate that every part number is the same between the two headphones except for:
-outer covers that have the model number engraved on them
-cord/plug assembly[the 7506 has a gold plated plug, the V6 has a nickel plated plug]
All other parts are listed as the same, including the transducers.
The price difference is due to different markets. The MDR-V6 is distributed through Sony's consumer division. The MDR-7506 is distributed through Sony's professional division. These two headphones are intended for different markets.
Is there a benefit to purchasing the MDR-7506? Maybe. It does not involve the actual product, but instead the warranty of the product. Some complaints have surfaced online within the last couple of years that when the MDR-V6 has a problem, Sony's consumer support department wants to replace it with the Sony MDR-V600[a different and inferior headphone, but Sony lists this as a replacement for the V6] instead of providing a replacement MDR-V6 or fixing the MDR-V6. The MDR-7506 will be replaced with a MDR-7506 or repaired. Consider the $30 premium to be the cost of a warranty. However, if you are interested in savings, www.simplycheap.com currently has factory refurbished MDR-V6 headphones for $50. Sony factory refurbished headphones are in perfect/as new condition according to my experience with 2 Sony factory refurbished headphones.
-Chris
Jack Hammer
Jack Hammer
Ratings
201
#3
Just saw some sennheiser 590's......
...I was just looking around at Ubid and they have some sennheiser HD590's for $89. I think those are a better set? How do they compare?
Thanks
Jeff
WmAx
WmAx
Ratings
1,417
#4
Thanks
Jeff
I have seen/handled the HD590, but I have not listened to the product. The construction quality is vastly inferior to the MDR-7506/MDR-V6. This is the only thing that I can comment on in regards to the HD590. The MDR-7506/MDR-V6 is a very linear headphone, however, and I have never used a more accurate headphone[Beyer DT880 might be slightly better in accuracy, but I have not had a chance to do a proper direct miced comparison yet with the DT880, and because the DT880 is an open backed headphone this will further complicate the comparison procedure]. But realize that this accuracy may work against you for most commercial recordings, which are not engineered to be accurate. Also, despite the high accuracy of the MDR-7506/MDR-V6, there is a notch in the response at about 200Hz that causes the midrange to sound somewhat thin over extended listening periods; but I am nitpicking. If you are interested in the particular flaws of the MDR-7506, please refer my analysis/measurements that can be found in the following thread:
http://forums.audioholics.com/forums/showthread.php?p=46352#post46352
-Chris
Jack Hammer
Jack Hammer
Ratings
201
#5
With that in mind...
... I'm going to pick up a pair in the next few weeks. For the slight difference in price, I'll go with the 7506's.
WmAx, I really didn't understand the technical stuff in your other post, but it was enough to sell me. That and the fact that I really like accurate sound, even though it does sometimes make flaws very apparant in what I'm listening to.
Thanks again
Jeff
WmAx
WmAx
Ratings
1,417
#6
Thanks again
Jeff
Please report back and provide your opinion(s) concerning this headphone after you have aquired the product.
Good luck!
-Chris
jaxvon
jaxvon
Ratings
103
#7
I think you'll like the 7506s. I have a pair (Per WmAx's recommendation) and I couldn't be happier. I use them every day for pleasure listening, and occasionally when I'm goofing off in the studio (which unfortunately isn't very often). Now all I need is a good softare PEQ so I can apply Chris's EQ curves properly. Graphic EQ just doesn't cut it.
