When would an AVR plus power amplifier combo be advantageous over a standalone AVR?
Some scenarios I can think of are the following:
1. Would a Yamaha RX-V663 paired with an Emotiva UPA-7 (125w x 7) be significantly better than that of an Onkyo TX-SR805 or Yamaha RX-V1800 (Both at 130w x 7)?
2. How about a Yamaha RX-V663 (95w x 7) alone, there's 30 watts difference with having the Emotiva UPA-7 (125w x 7)? Would there be any advantage aside from being able to crank the volume higher with the Emotiva?
Would the AVR plus power amplifier combo only be useful if you will drive your speakers at higher than usual volumes (Which also partially means that the setup will be in a large room, say 3,500+ cu ft)?
When using only a 5.1 or 6.1 setup, do 7.1 AVRs re-route amplifier power to only the channels that are in use? I've noticed that for power amplifiers, power ratings increase per channel if all channels are not in use.
What scenarios would require/benefit from the use of power amplifiers? What are the main uses of power amplifiers aside from being able to drive speakers at a higher volume than standalone AVRs?
Just curious about how these things really work. Any help would be greatly appreciated. Thanks!
