Dielectric grease as a lubricant for RCA?
Alex2507
Alex2507
Some RCA cables put a death grip on jacks. I read somewhere that the grease was an acceptable solution for that. Since dielectric means insulator I just thought I'd ask if it actually was a good idea. After reading up on some of the topics discussed here at AH I figured this would be the place to get a qualified answer before I reassembled my gear again. Thanks.
Dielectric grease is used to prevent oxidation, and yes it is nonconductive. I'd try something like Caig Deoxit or ProGold instead if it is actually a problem.
Alex2507
Alex2507
I don't know that it is a problem. After giving the matter way too much thought I started "wondering" if it might be adding to the resistance. Thanks for pointing out that it prevents oxidation. The death grip feature of my interconnects should insure metal to metal contact while the grease inhibits oxidation. Right? Which is good. Right? In any event I'll look into the products you mentioned. I'm guessing that these products are conductive.
I have used the dielectric grease as a lubricant before. It does help in disconnecting the cable. I can't really tell if my HD was more HD with out the grease. Thanks for the input on the other 2 products.
MDS
The only snake oil would be the claims of drastically improved picture quality. Maybe picture quality improved due to being able to actually make a full connection to the input jacks but it certainly isn't because of any magic properties of the grease itself.
Alex2507
Alex2507
I'm gonna do as Mr. Garcia suggested and use Deoxit "if it is actually a problem". Meaning the dielectic grease causing resistance. Using grease hasn't been a problem in the past so I'm not going to spend the time and money on hoped for improvements.
I do after all have very healthy connections as MDS mentioned is important. Thanks again.
highfihoney
highfihoney
Yes they are conductive & from what ive read can end up being a big problem later on,ive no personal experience with them but i have read on more than one occasion where that goop has shorted out peoples amps & such.
I dont know for sure but it would seem to me that putting a conductive material anywhere in,on or around any electronic equipment is a disaster waiting to happen.
I use Deoxit and it works great. I put it on and leave it sit for a while and then "polish" it off. It doesn't make the sound any better, IMO, but it definitely works as a contact cleaner. It has helped me out in flash lights, phone batteries, and an old 70s receiver. The key is, use only as much as you need and wipe excess off. I use the brush on type, not the spray type. The tiny little "fingernail polish" bottle has lasted me quite some time as well, as you don't really need much. I haven't tried it on any stubborn RCAs though.
Dielectric grease is theoretically supposed to be pushed out of the way by the contacting metal surfaces so that there is still contact, then the grease prevents oxides from getting into that contact area by filling in the gap around the contact area. I use it on my spark plug wires but not much else.
Alex2507
Alex2507
I think it's pretty obvious which cables I'm using. I'm not proud of it or anything but there it is. I've been at this a couple of years now and have ended up with what I have wire-wise through eBay so cost-wise it's not as bad as it could be. Quality-wise it could be better. But man does that turbine cut crap ever hold on.
Between grasping the concept of optical audio, adding a Denon 1920 DVD player with 6 channel preouts and a move not too too long ago this poor system has been comming apart alot. I'm putting it together temporarily once again until I get this in-wall cabinet finished and installed. The dielectric has helped in the past and I would have used it again if I hadn't been to Radio Shack this morning. Contact Cleaner & Lubricant. Who knew? Along with some 57 sylable propylenes it contains white mineral oil. Hence cleaner and lube. Instead of spraying it everywhere I shot a little into the cap and used a Q-Tip to clean and lube the RCA jacks. It does evaporate pretty quickly. I'll take the interconnects outside and blast them with the spray can. And I do mean blast. Over all I like the look of the cleaned RCA jacks. Nice and shiny and the Q-tip has a grayish metallic color to it. So mine will sound better at least in my own mind because I SAW the dirty Q-tips. Kidding.
Yeah, blasting a conductive fluid into a AVR couldn't be good. Unless it was plugged in, Right? Thanks for the help.
