The Chukker said:
You say SED is burn in susceptible, another poster says it is not. Who is correct, and what is the evidence?
It depends on what you mean by "susceptible" to burn-in. SED is no more susceptible to it than any CRT television.. my TV is ten or twelve years old and I've never had a problem with it.
The "evidence" is simply the technology.. an SED display works on the same basic principle as a CRT.. projected electrons colliding with a phosphor coating on the screen, which illuminates in various shades of color, depending on the intensity of the electron beam hitting it. That's what makes them susceptible to burn-in.. if a certain section of the screen is exposed long-term to a constant electron beam, it becomes charged and permanently altered.. leaving a residual image even after the electron beam is deactivated or changed. The only thing that's changed in SED TVs is how the electrons are delivered to the screen. Where a CRT has only three beams (one per color, red, blue, green) controlled by a large electromagnet array and projected through a large vaccuum tube, SED TVs use individual beams for each pixel. So instead of three electron guns, you've got six million, two hundred twenty thousand, and eight hundred electron guns.
The delivery method is different, but the actual display technology itself is unchanged (which is why SEDs also have CRT-quality displays in terms of brightness, contrast, and color). Hence also the susceptiblity to burn-in. But it's no more prevelant than any CRT. I don't expect it to be a problem for anyone, really. As I understand it, plasmas and projection TVs are FAR more susceptible to it than a CRT or SED display will ever be.
The change in the structure of the TV is also cause for concern. They've said that SED TVs have the capability of being far cheaper to manufacture than plasma or LCD TVs, but there's a catch... with over six million electron emitters, the chances of a fault is much higher.. they'll be having yield problems the same as plasmas and LCDs, and sadly, that will probably keep the cost pretty high for a while yet.
