Did some component rearraning for my digital media
3db
3db
Three years back, I bought a non networked digital media player (Iomega) that came equipped with a 1TB disk for $100. I snagged it just for the disk and started to use as it played almost any kind of media you could toss into its hard drive. However, I got tired of unplugging it from the AVR and plugging it into the PC to add more content. Its then that I purchased a Western Digital SMP Live media player (WD). I left the Iomega on the PC and accessed its contents through the network via the WD. That worked but everytime I turned off the PC, the WD would recompile the media library after turning on the PC. It takes 15 minutes or so to compile. I got tired of having to use the PC to stream my digital media. A year after I bought the Iomega, I purchased two 1TB disk drives (again just $99) for backup purposes for my kids PCs. My kids haven't been using them to back up their data so I thought I would put at least one to use for now. I copied the contents of the Iomega onto the hard drive (took a good 5 hours to do) and then plugged the hard drive directly into the WD. I removed the network share of the WD and voila...I'm independent of the PC. I'm also ale to update the contents of the hard drive via the WD using the PC. I should have done this 2 years ago.
Here is a screen shots.. the WD is on the left.. the hard drive is tucked behind the TV and out of sight.
itschris
itschris
Moderator
That looks really nice. In the end the most important part of any exercise like this is to have a sweet looking interface!
