bears_t2
bears_t2
Just for a pair of Paradigm Titan v3 used. Got them for 50.00. I think they sound great for a front speaker replacing my klipsch quintet 3s.. Did I do ok? Im using a 818 to drive them. I know they cant take too much power. Cant seem to find out too much about the Paradigms. Thanks in advance for the insights.
Cos
Cos
Its definitely an upgrade from the Quintet 3 you were using, and for $50.00 that's not a bad deal at all. So to sum up, that's a darn good speaker for $50.00 :)
bears_t2
bears_t2
Hmmmm... 96 views and nobody else thinks I did ok except for cos? And BTW cos thank you very much sir.
3db
3db
Its a better speaker, thats for sure. As long as you like their sound, then you've done well.
PHANofPHUNK
PHANofPHUNK
I don't think you could do much better for $50. They do have their caveats though, however it is a significant upgrade to the klipsch.
Have fun!
