Hi everybody,
BTW : Yes I looked at the pdf in the articles section but my equipment seems different from the ones depicted.
A lil about me. I'm 18 (will be 19 the 15 th of january) and i'm studying in mechanical engineering. I don't know much about home theater and stuff like this but I usually learn pretty fast when somebody explains
Ohh and i'm from quebec so I speak french and english is my secondary language.
So i'm new to the forum. Yeah well for christmas I got my first HTIB from my parents. It's a Yamaha YHT-160 (
http://www.yamaha.com/yec/products/HTIB/HTIB_160_1.htm and they also bought a yamaha dvd .. a DVD-S550
http://www.yamaha.com/yec/products/DVD_CD/DVDS550.htm. I don't know much and it's my first ''home theater'' so I don't know if it's good or not but I got it as a x-mas present and I won't complain about this even if it's not the best.
I started installing it in my room. My parents actually boutght everything that they had to buy in order to install it (at least everything that the seller told them they needed). So I had lots of speaker wire, 1 X S-Video cable and 1 coaxial cable. I wired all the speakers as they should and then came the time to hook up the coax and s-video cable. (in order to be as clear as possible please take a look at the links I posted at the end of the post where you can see the backplates of my equipment). I saw the coax. jack on the DVD, so I hooked up one end of the coax to this jack. Then I checked out on the AV receiver and noticed there was no jack for DVD coax. only one jack for CD coax. so I hooked the other end of the coax. wire to the cd coax wire. And then I hooked the S-Video from the DVD directly to the TV as I did not see any s-video input/output on the AV receiver.
I inserted a DVD in the dvd player and I had the image but no sound. The AV was in DVD mode. So I figured that if I wired the coax cable to the CD coax input on the AV I should try to put the AV receiver on CD mode while still listening to the DVD. Then I had sound. I basically set-up the av receiver in order to get ''good'' sound but now i'm worried.
What am I worried about ? well I'm worried that I won't get a real 5.1 dolby digital surround sound (like a 3d sound, you know when a spaceship passes in the back when watching star wars at the movie theater, you hear it from behind). I think cd and dvd might not be encoded the same way and that a dvd that's audio output is brought in the AV receiver through the audio input might not be interpreted correctly from the AV receiver (that last sentence might not be easy to get but.... try to get it
). So basically my questions are.
FIRST : Did I connect everything correctly
SECOND : Will I be able to get reall dolby digital surround effect wired like that or will I have to buy a really expensive optical wire to wire the dvd to the AV receiver ??
THIRD : With my equipment is there a way to listen normal analog cable TV with my home theater system or can I only listen to DVD's and CD's with it ?
Well that was a pretty long post. I know that might be dull to read and to answer for you gurus out there but I really need your help.
Thanks a lot
Please refer to these links to see the backplate of the DVD and AV receiver:
DVD BACKPANEL :
AV RECEIVER BACK PANEL :
http://www.yamaha.com/yec/products/HTIB/HTR5830.htm
EDIT : and my TV only has s-video and 8 RCA out/input (2 video, 3 +, 3-)
