MidnightSensi
I had a lot of fun playing with the JLs and got some good results, so I'm going to attempt my first home subwoofer. The driver I want to use is a Diamond Audio D6 15" in a vented enclosure. Here is the design:
I based the idea of how to vent it off the Infinity Kappa Perfect builds here, but I had to go wider because this driver pumps so much air, so the entire bottom of the enclosure becomes part of the vent.
The Driver:
Diamond Audio D6 15" dual 4-ohm
SPL(dB):87
Re(Series) 6.0
Qms: 4.52
Qes: 0.58
Qts: 0.51
Fs: 28Hz
Vas: 74L
Cms (MM/n):0.081
Mm(g): 398
Sd(m^2):0.080
BL (T*M):27.2
Xmax mm): 15
Pwr(w) nom/max: 750/1500
My box will be a 5.5ft^3 vented with a 22Hz tune. Vent is 3inx18in (HxW) and 49.35in long.
What do you guys think?
It's dual 4-ohm, so should I get a two channel amplifier and run one voice coil off each channel?
The Driver:
SPL(dB):87
Re(Series) 6.0
Qms: 4.52
Qes: 0.58
Qts: 0.51
Fs: 28Hz
Vas: 74L
Cms (MM/n):0.081
Mm(g): 398
Sd(m^2):0.080
BL (T*M):27.2
Xmax mm): 15
