Bought a Panasonic Viera 54" plasma last year. Discovered that the sound from a flat panel is really bad. Bought a Yamaha surround sound receiver, a cambridge soundworks center channel speaker, and a Definitive Tech SuperCube® II. I owned a pair of Cambridge Soundworks Newton Series M80's so used those for fronts. Don't have rears or presence speakers.
My problem is that the dialog on a lot of movies does not seem to be balanced with the music and effects sounds. So you turn up the volume to hear the dialog and then then when music or an action scene comes up it's REALLY loud.
I've tried adjusting so that the center channel is all the way up and the fronts are turned down but it just doesn't seem to work. Could it be that the center channel is just not as efficient as the fronts and there for is softer?
Also, my receiver came with a microphone to use with some kind of calibration system. Should I just try that?
