Hey all,
This is my first post so a hello to all.
Im designing a set of bookshelves using a woofer and tweeter.
I have built other speakers before but never had to play with the impedance/resistance.
Using 2 8ohm drivers the overall impedance is ofcourse 16 or 4
What I was curious to know is if you can chuck in a resistor either in series with the woofer or tweeter? or in parallel?
Or will this consume too much and be a total waste?
Thanks again
Edit::
Or will wiring them at 16ohm be ok? How much power will I be loosing compared to 8ohm?
Thanks
