Denon X7200Wa clipping
poweragent
I have the following setup:
Denon X7200WA
(2) Speakercraft AIM Cinema Fives
(1) Speakercraft LCR 5 Five (Center Ch)
(2) B&W 10 CM Subwoofer (LFE)
(2) Speakercraft AIM 8 Fives (Rear Surrounds
(2) Speakercraft AIM Wide Five (Height (ATMOS)
(2) Speakercraft AIM 8 Five (Height (ATMOS)
It is set up as 5.2.4 system. My problem is I'm getting what I believe to be "Clipping" out of my Cinema Fives (right Channel) Is it clipping or a blown speaker? How do I determine which
KEW
KEW
Swap the L & R speakers wires at the Denon and see if the problem goes to the left speaker (signal problem - clipping) or stays with the right speaker (speaker problem)
As KEW suggested, but be sure to play the same material and at the same volume. I know it sounds too obvious, but I'll say it just in case..
M Code
M Code
Do U have any volume control attenuator pads installed on the problem channel?
Just my $0.02... ;)
WaynePflughaupt
WaynePflughaupt
Clipping will manifest at high volume levels. A blown speaker will sound bad at any volume level.
Regards,
Wayne A. Pflughaupt
