Denon x5200 handshake issue with LG OLED e7p
the machine
the machine
Hello all,
Want to get some opinions here and see if anyone has any solutions. I previously had an LG LM7700 and recently upgraded to the LG OLED 65 e7p. When it first arrived and I hooked it up there was no signal showing on the screen. I tried different HDMI ports and turned the TV on and off a bunch of times, then it finally came on.
I swapped out HDMI cables but I kept having this issue, only it was less frequent. The first time I had to restart and or unplug/plug back in my HDMI cable 6 or 7 times before a picture came on the TV. Now, most of the time it starts right up. Occasionally I have to turn everything off once or twice but then the picture comes on. Sometimes it comes on after briefly showing the no signal detected screen for a few seconds, and I can hear the audio.
The previous TV never had any of these issues. The cable box is less than a month old and never had any issues either. It goes from Comcast 4k cable box to Denon 5200 to TV, all using HDMI 2.0 cables.
Are there any settings I should try on the receiver to try an alleviate this issue? Maybe a hard restart of the receiver? I'm also thinking of trying a different receiver to see if it has any of the same issues.
Thanks for your input
everettT
everettT
Is CEC turned on? ARC? In the display. If so try turning off.
