Denon X4000 Remote Volume is FAST
herbu
Anybody else notice the volume control on their X4000 remote control operates at super sonic speed? Seriously, pressing and holding the down/up button on the remote scrolls the volume VERY quickly. I would guess ~200 milliseconds gives you ~10dB change. It means a lot of instant press/release to walk the volume 1dB at a time to where you want it. Tough to consistently execute the difference in 10ths of a second on the remote.
Could there be a setting I can't find for this?
Thanks.
I don't even use my Denon remote controls. They are in the closet.
I always use my iPad to control my Denon.
ReUpRo
Yeah, it zooms up and down. The minutest delay in coming off the button and one is 5-10dB off the intended volume.
I too am interested in knowing the answer to your question.
M Code
M Code
Be advised...
Soon, Denon is releasing a firmware update to fix the Dolby Digital + NetFlix & HBO To-Go issues...
Hopefully this problem will be addressed.,,
Just my $0.05... ;)
