Denon x1300 or Denon x1400hw?
bradymartin
ive been waiting for the x1300 to go on sale for $300 or less
but today frys has the x1400 for $260 total
is the only difference the 1400 has heos? i dont care about that. should i keep waiting for a sale on the 1300?
ThunderClap
Check accessories 4 less before you do anything.
I just got the Marantz 5011 $899 currently for $449 shipped .
Spectacular
If you can get the 1400 for less than the 1300 go for it, they're very similar otherwise (or use the comparison tool at the Denon site to see if there's any other difference but Heos...).
bradymartin
i got the 1400 but quick question
for now im using it on my computer for strictly 2 channel music, youtube etc.
does it matter if i connect a pair of speakers to the front r/l terminals, or should i connect them to zone 2 (surround back)?
just want to get the best sound and amplification
the manual is confusing i guess, both surround back and pre outs are named zone 2. not using an external amplifier
everettT
everettT
On your main LR, especially if you want to use the RC
Generally main L/R would give you the best options (like Audyssey mentioned). Sounds like with your zone 2 you have the option of using the built-in amps for surround back or an external amp thru the pre-outs.
bradymartin
i tried lfe plus main and towers set to large, switched back to bypass l/f several times to see which one i like better. for music only.
something odd happened though
lfe plus main and towers set to large. when i went to speaker options, crossovers for towers said full, and greyed out. so i knew the settings were correct
but while switching back and forth i tried lfe plus main again. but this time in speaker options, towers said large, but not full in crossovers. crossovers still said 80.
wondering if i forgot something
On my Denon the speaker configuration screen would use large/small terminology; the crossover configuration screen when speakers are set to large, will say "full band" rather than a specific crossover frequency....
bradymartin
strange, i cant figure it out.
audyssey set to bypass
lfe + main
towers set to large, but in towers crossovers still says 80. not full band and greyed out like yesterday
must be some setting im missing
lfe + main
Could just be a glitch, try a soft reset and see if that persists.
KenM10759
KenM10759
Spectacular
My son just picked up one of those too, his from Best Buy, for the same price. He speaks glowingly of it as well.
bradymartin
if anyones curious.
i got it to say "full" now instead of 80 crossover
bass cant be set to lfe plus main, so i set it back to lfe and voila
now im experimenting between large and small at 80 crossover, always bypass l&r
