Teetertotter?
Teetertotter?
Give it a try and see if it is good for you or not. See if it has all the controls you require. I have the Roku TV remote, DTV remote, and the Denon AVR remote. I don't need any more for my applications. The DTV remote turns every thing off/on, changes channels, and controls volume. If I need internet music via the Denon AVR, I use that remote.
Perhaps others will chime in. denon app for android - Search (bing.com)
Squishman
Squishman
I was thinking I'd use ethernet since the modem is right there one shelf down. If I did, would wifi find the amp?
Squishman
Squishman
.... still waiting for Amazon to put it on the road. Does not show out for delivery yet.
Your tablet should find the AVR as long as your WiFi isn't set up to block anything. It's just like any other device on the network, at that point. Open the app, search fro devices and connect. If it doesn't find the AVR automatically, you can enter the IP address (you would find this in the AVR's Network setup area).
If it's close, I would hard wire it- read my tagline at the bottom of this post.
Squishman
Squishman
Not coming today. They gave me $10 for the inconvenience. ha. I'll take it.
