Mmm... I wonder if receivers from different manufacturers with Audyssey MultEQ XT have different results, or if it's the rooms of individuals that affect the final results the most?
Also the number of microphone measurements might have something to do with that too?
And from what I read at Audyssey, Chris seems to recommend turning off the digital EQ of the sub(s) for most accurate results.
Am I missing something or is that new SVS sub revolutionary?
From what I read about that new SVS sub with it's own EQ, it is exactly that; it's own EQ and that you should turn Audyssey off (or more exactly that the SVS will take care of not letting Audyssey filters the low bass), so only the higher frequencies (mids and highs from the other speakers) will be filtered by Audyssey, while the SVS sub with it's own digital EQ system will filter it's own low frequencies?
Mmm... I'm gonna need some more research into this, I guess.
It always get more complex as more stuff get released; Dolby Pro Logic IIz (matrix) into two height channels, Audyssey DSX (Dynamic Surround Expansion) with two height and two front wide side channels. Audyssey PRO capability. Tons of extra features...
And the new Denon AVR-4810ci, a 9.3-channel speaker configuration, with 9 power amps inside (multi mono-block construction), 140 watts times 9, ouch!
Three subwoofer outputs? Dacs = TI PCM-1791a times 4 (stereo dacs)!!! Well probably 6 now for 12 channels (9.3).
For $3,000, why not use the 1796 in true differential mode for all channels?
You will need 12 stereo dacs (chips) for that (24 single dacs).
Anyway, much cheaper than the 1792.
New video processor by Anchor Bay Technology, VRS ABT-2010; finally Denon is getting somewhere here.
Denon Link version 4, with jitter reduction.
Mmm... Hard to keep up...
HDMI version 1.4
High resolution video with 4k
Ultra high resolution video with 8k and even more...
True multicolor 3D video
Holographic technology
0.3mm flat panel display
flat speakers
Mmm.... I think I need a break...or maybe not, just have to keep up with all of it in the name of a better technology (I hope) for a better experience in Sound and Picture quality, and an economy due to rebound at some point. Money got to flow freely again, it is our destiny and our principles.
I'll do my best trying to keep up.
Bob
