Denon S750H zone 2 volume
I
Illiniwoods
I am having trouble adjusting volume in zone 2 of my Denon S750H. I have followed manual, Zone 2 Source and Master Volume, or Zone 2 on remote and volume up/down arrows, but is frozen on 60. “Fixed” on Denon AVR app too. So how do I adjust volume in Zone 2?
Might explain a bit more on just what connections and setup you've done initially, but a glance at the manual seems to confirm you're doing what you need to in general....might try a soft reset (unplug the avr for a bit) and/or a full/microprocessor/factory reset per the manual's instructions (pg 227 of the pdf manual).
Interesting, looked on the back thinking maybe he had zone 2 pre-outs with a fixed/variable thing but didn't think something with only speaker outs would have a fixed mode....altho I suppose I can maybe see a use for that (but since it has a power on volume level wonder how useful that really is).
BMXTRIX
BMXTRIX
Some people hook up zone 2 for whole house audio rather than just a single secondary room. So, you may go into a 4-way speaker selector, or similar, then out to multiple rooms with each room having its own local volume control to run things. It's less than ideal, but a perfectly workable setup as long as people don't want the volume up that loud. Great for background listening I would expect. So, that's when you would set it to fixed and just leave it. For full operation w/volume, then people should leave it set to variable so they don't run into this issue.
