I had been looking for a setup that either required no rear speakers or used wireless ones. I ended up pickup up a Denon S-101 setup this weekend but before taking it out of the box I am having some second thooughts. I had looked at the YSP-1, but thought it was just a little out of my pice range, especially since I would most likely want to but a Sub as well. At the store I listened to the Boston Sound bar and the S-101. I think the SoundBars surround was a tad better then the S-101, but I really liked the fact the S-101 had the ipod input. Any way I at Best Buy and saw teh YSP-800. After reading some reviews I am wondering if I would be better off taking the S-101 back and getting a YSP-800 along with a YST-FSW100 sub. I know I will lose the ipod direct connection but can just use a Mini to RCA for that. I have another DVD player that I could use that has HDMI/Coax outs if I went the Yamaha route.
The setup is for a 42" Sony LCD Projection TV, will be used 50/50 for movies and music. I am probably more concered about the music sounding good then the surround being 100% accuracte. Also due to the shallow depth of the room the seating is against the rear wall, and the side walls are good 10ft either way from the center. In reading reviews of the YSP-800 someone commented that having the seating against the wall was potentially a problem so that alone may make the choice for me.
So just looking for some feedback or opinions.
