I have the blue remote, and it has the following problem: if I turn the receiver on on the unit front panel and turn it off using the remote, the remote locks itself, nothing works and its light doesn`t turn off. The only way to unlock it is by removing the batteries.
Other than that (big problem) it works properly.
