Denon POA4400 Reference-Class Mono amps
Whitey80
Whitey80
Exceptional condition. Recapped. Near flawless cosmetically. Black brushed aluminum finish. These big mono amps have served me well for quite some time driving my big Maggies. But have switched to tubes, so no sense in letting them die in a closet when they could be living on in another system.
The Nelson Pass circuit design allows them to operate in class A to very high output levels before switching to A/B.
Massive torroidal transformer and four 8200UF caps in each make sure that these amps never compress.
(NOTE: THIS IS A MATCHING PAIR.)
This is the U.S. model (not the "a") with the large binding posts.
Balanced XLR and unbalanced RCA inputs.
System: Transistor Power Amplifier (2x Mono)
Power Amplifier
Speaker Outputs: 2 x 2 Speakers (2x)
Continuous Power 4Ω: 250 ( + 250; DIN) Watts
Continuous power 8Ω: 160 (+ 160) Watts
Frequency Response: 1-300,000 (+0/-3 dB) HZ
Input Sensitivity: 1,000 mV
Input Impedance: 25 kΩ
Signal to Noise Ratio: 123 (IHF A) db A, short circuited
Harmonic Distortion: < 0.002 (-3 dB) % at rated output
2. Physical
Dimensions in Inches: 12.2 x 7.6 x 16.5 (2x) (w) x (h) x (d)
Dimensions in mm: 310 x 192 x 420 (2x) (w) x (h) x (d)
Weight in lbs: 22.7 (2x) lbs
Weight in Kg: 10.3 (2x) Kg
photo of actual unit. (just one in photo, it's what I have on PC already)
$550 + split shipping.
GranteedEV
GranteedEV
that's the -3db point...
20 + 20 = 40
40 + 40 = 80
80 + 80 = 160
160 + 160 = 340
That's just under four octaves above 20khz.
Whitey80
Whitey80
haha.....they don't like abbrv. with the "k", it makes it look more awesome.
Whitey80
Whitey80
Im selling to buy something else...so if you happen to have an Emotiva erc and xda, straight trade would work too
