So perhaps someone can help point me in the correct direction. Having a problem with deep clean based response. Current gear is Denon 3300, M&K LCR-750 for Left,Front and Right Center speakers with M&k K-4 Tripole speakers(2). The Sub-woofer is a M&K MX-125 MK II.
I've reset my Denon 3300(0 out the channels and set distance) and set everything back up from a recent move including balancing the channels via the Denon with my realistic sound meter in an 18x16 room. Gone through Chesky Audit tests, music and positional sounds appear to be correct and sounds great!
I have specifically on the sub
settings dialed in the low pass filter on 75-80 and -3 on the based level
Problem is when I play DVD/BD movies, the base seems to "Galoop" in the heavy action rather than Rumble. Not sure when I moved if the settings got changed on the sub OR If I am missing something altogether.
Any recommendations on what to check?
