Denon DVD-2900 High End (SACD, DVD, DVD-Audio) Player
  • Thread starter Thread starter Hibbing
Hibbing
95
0
0
One year old, very lightly used, in mint/excellent condition! Original remote control, owners manual and box included. Retailed new in Canada for $2000.A superb, high end home theater DVD Player! Burr Browns and BM for DVD-A and SACD. $470
Pure Direct Mode The DVD2900 includes two Pure Direct modes that further improves sound quality. For example, during analog audio output, Pure Direct can turn off digital signal outputs, video signal outputs, and the front panel display which can easily influence the sound quality of the analog audio signals. The user can define which operations are to be turned off and store those preferences in memory.
Digital Bass Management When playing DVDVideo, DVDAudio or Super Audio CD sources, it is possible to preset speaker configurations. The crossover point is fixed at 80 Hz with 12 dB high and 24 dB low pass filter slopes.
SRS True Surround The DVD2900 is equipped with SRS's True Surround circuit, a highgrade surround virtualizer that lets you enjoy the excitement of 5channel audio with only using 2 speakers.
NewlyDeveloped Loading Mechanism for Suppression of Vibrations The newlydeveloped loading mechanism uses a guide and tray painted with protein material that is highly resistant to vibrations in order to prevent unwanted vibrations to the tray.
Specially Selected Parts for High Sound and Picture Quality
DVDR/RW (DVDVideo Recording Mode) Playback (*1)
CDR/RW (MP3 / JPEG) Playback (*1) The DVD2900 supports the CDR/RW format. It plays finalized CDR/RW discs containing MP3 audio files. It also reads still photos in the JPEG format taken by a digital camera.
Brilliant Black DVD2900 can pass below black video (PLUGE) via the progressive or interlace video outputs for correct monitor setup and optimum picture quality.
A Wealth of Picture Quality Adjustment Functions Contrast, Brightness, Hue, Sharpness, and Gamma can be adjusted as desired by the user.
Kodak Picture CD The DVD2900 also plays Picture CDs (Kodak format only).
On Screen Display
RS232C Port (Thirdparty system controls only) Includes a RS232C port to support an AMX, Crestron integrated control system.
Progressive Scan DVD-Audio/Video Super Audio CD Player
Powered by the Silicon Image/DVDO PureProgressive™ (SiI504) Decoding Engine - highest quality progressive decoding engine available
PureProgressive™ decoding features high speed ultra-resolution DSP at 6 Billion Operations Per Second (6 GOPS) with 64Mb external SDRAM
4 fields (2 frames) digital video processing for optimum motion detection and compensation
Accurate 2:3 pulldown detection and reconstruction, even with inaccurately flagged content
Optimum processing for film content, video content, graphics content and mixed-mode content
12fps (Animation), Video overlay detection and processing
New 'Chroma Bug Free' Mitsubishi MPEG/DVD-Audio Decoder
Sony CXD-2753 Second Generation DSD Decoder
High resolution Analog Devices ADV-7300, 12 bit/108 MHz, 4:4:4, Video D/A Conversion system featuring Noise Shaped Video processing - interlaced and progressive output
4x Oversampling Progressive and 8x Interlace output
2X DVD read speed; 4X CD/CD-R/CD-RW read speed; with 8MB drive buffer memory
Built-in Dolby Digital, dts, DVD-Audio and discrete SACD decoders with 5.1 analog outputs
Custom Built to DENON Specifications - Burr-Brown 24-bit, 192-kHz DSD 1790 Audio DACs that decode PCM and DSD signals discretely with no down-conversion of DSD
Full Digital Bass Management for DVD-Audio, featuring Analog Devices Melody 32-bit processor; 80Hz crossover with 12dB high and 24dB low pass slopes; Adjustable delay time (0-15ms)and Channel Levels
Full Digital Bass Management for SACD; 80Hz crossover with 12/24dB slopes on all channels; Adjustable channel levels
MP3 Playback
Plays Audio/Video CDs; DVD-Audio/Video; Super Audio CD; DVD-R/RW(conditional); Audio CD-R; Audio CD-RW; MP3 CD-R; MP3 CD-RW
JPEG photo file viewer, Kodak Picture CD and Fujicolor CD compatible
24/96 digital output; optical and coaxial
4:3 Shrink and Zoom Controls
Pure Direct Modes to defeat unneeded portions of player for the ultimate in audio performance
2 box, 5 block internal layout to isolate analog, digital and video circuits
Wideband relay switched component video output
Variable Black Level (Setup): 0 and 7.5 IRE
Passes below-black (PLUGE) on progressive and interlace outputs
5 Picture Memories, with adjustable tint, brightness, contrast, sharpness and Gamma
SuperSub Alias Filter on Progressive and Interlace for Luminance and Chrominance signals
(1)Composite and (1)"S" video outputs
SRS TruSurround
RS-232C and remote in/out ports
Glo-Key remote control
Dimensions: 17.1"w x 5.2"h x 13.0"d
