Hi all !
I've got problems with a Denon DVD-1920 I purchased some three weeks ago.
I'm running it through the component outputs.
The first problem is that, for certain DVDs, on scenes where there is a lot of movement (that is, when the bitrate becomes momentarily very high), the player will black out (the image is lost) until it can start reading normally again. This does not affect the audio. Also, this is only true when the de-interlacing is turned on. Turning it off removes the problem. This problem is repeatable, in that the same scene will always cause the blackout. And no, the disc is not dirty.
The second problem is that sometimes, the image will black out, but this is irregular: it does not seem to be caused by any scene in particular. Again, the sound still works. This problem is more alarming because it vaguely looks like an electrical problem, and when the image is lost, it can be a while before it comes back. The unit I original bought was returned to the store because of this problem, but my new unit still has it. It also sounds like an electrical problem, because when the image is lost, the TV makes a sound, as if it was shutting down. This is very weird. And FYI, I also changed the wires, the problem is still present.
The final problem is that, although the reviews are generally pretty good on the internet, I still find the de-interlacing to be somewhat problematic in that jaggies are still present.
Did anybody ever experience this too ? Any solutions ?
