Denon (DRA-395) Receiver
Trudilu
Where can I post an issue that I have with my Denon receiver?
My receiver suddenly stopped working (the sound/display) after a sudden and unexpected surge in volume!! I had to run downstairs to turn it down so not to freak my neighbors out. I was just watching a U-tube video before that, and everything was fine - so I don't know what I did?
It turns on, but the sound and display (showing my various peripherals attached to it) has disappeared. Everything I have goes through this receiver, so it has been pretty distressing.
I tried to 'reset' it per instruction online - didn't work. Someone suggested it could be a fuse, which I've been looking to find online - but I can't find the fuse anywhere! First I need the type of fuse I would need. I have a tech person who is willing to open it up to put it in and hopefully get it started again.
I just know there is a direct correlation between the VERY loud sound and the subsequent dysfunction of my reciever.
I'd appreciate your help. Thank you
Trudi
I've had amps act like that just before dying. If it doesn't react to a reset probably not much you can do. For a fuse have you looked at the service manuals available on line?
Trudilu
I have the original manuals that it came with, and can't find any fuse-related information. But I will look online anyway.
I just seems like a wierd way to die. I know it has to do with the sudden loud volume so I can't help think that it didn't completely kill my reciever - but that something shorted out or something like that.
