Denon DP 300F Vs. Dual CS 415-2
MG350
MG350
Greetings all...
I'm in the market for a new turntable and i have narrowed the selection down to either the Denon DP 300f or the Dual CS 415-2. I was wondering if anyone has any experience with either table? Any intel would be greatly appreciated. Thanks.
audiofox
MG350
MG350
The Thorens table is sweet, very similar to the Dual. I'm not a fan of the Project table. I don't like the way you change the speeds, by moving the belt manually...
3db
3db
I have a ProJect Xpression II and its a great table, running very quiet. The tonearm is phenomenal on this. It is a pain in teh ?ss to switch speeds but I listen to LPs at 33 1/3 so this is a non issue. You could purchase a ProJect speed box which allows you to vary the speed through it instead of changing belts.
audiofox
I have to agree-unless you have a large collection of 45 singles or audiophile 45 rpm reissues, manual belt changes are not something you will have to deal with much, if at all. My VPI HW-19 Mk IV (a $2,000+ table when new) also requires moving the belt on the spindle for speed changes, which is typical for most, if not all, high end turntables. I did get an SDS (VPI's electronic speed control), which lets me change the speed electronically and control the variations in AC supply frequency (the TT has an AC motor), but I don't think I have ever used that feature since I set it up.
