Denon DP-300F Fully Automatic Analog Turntable Overview
HTKamikazee
Audioholics Sheriff
While many audio enthusiasts insist on this digital vs analog debate, one thing remains true.... vinyl is still alive!
Denon knows this and that's why they launched the DP-300F Fully Automatic Analog Turntable which is their entry-level offering. According to Denon, this unit has been designed with heavier base construction for reduced vibration and improved performance.
The new tonearm with removable headshell makes cartridge replacement simple.
The DP-300F has an automatic start-up feature that allows the turntable to begin play with the touch of a single button. It also has a manual lifter mechanism that allows you to place the needle on the record wherever you want. I don't have a turntable in my current setup and the DP-300F is starting to make me want one.
Some of its features:
  • Excellent listening turntable at entry-level price, easily upgrades, solid build / heavy.
  • Automatic operation - turntable plays at the touch of a button + tone arm returns to armrest when done.
  • Built-in phono pre-amp (for amplifiers that do not have phono inputs), switchable (on-off switch is under the platter).
  • Removable and upgradable cartridge pre-mounted on removable headshell, Denon MM Cartridge included.
  • Rigid die-cast aluminum base to reduce vibration and improve performance. Refined gloss finish.
  • Belt drive
  • 33 / 45 RPM button.
  • Manual arm lifter (for optional manual operation)
Specification:
  • Drive system: Belt drive
  • Speed: 33 1/3, 45 rpm
  • Wow & flutter: 0.10% (WRMS).
  • Tone arm Type: Straight
  • Stylus pressure range: 0 – 4.0g
  • Cartridge Type: MM
  • Needle pressure: 2.0g
  • Cartridge Weight: 5.0g
  • Replacement needle: DSN-85
  • Power supply: AC 120V, 60 Hz
  • Dimensions 434 x 122 x 38 mm / 17.1" x 4.8" x 15.0"
  • Weight 5.5 kg, 12.13 lbs.
  • Comes with MM Cartridge45
Price: $349.99
Additional pictures:
Don't you want one after seeing this nice turntable?
Added to wish list :D Since I need one and haven't owned a TT in a LONG time.
slipperybidness
slipperybidness
Haven't started looking into it yet, but ProJect is on the radar as well.
My peeve with Pro-Ject is that little hanging weight anti skate device. It just looks cheap and I don't like it.
I notice that even many of their higher end offerings use that same setup. So, I guess it's good and it does the job. But I still don't like seeing that little weight dangling there.
3db
3db
The tone arm on the ProJect Debut is a much better toneram than is found on the Denon as depicited in this thread offering with the fancy antiskate mechanism. ;)
slipperybidness
slipperybidness
Yup.
I'm certain that any Pro-Ject will be better than this Denon, don't get me wrong.
And, I'm sure the anti skate on the Pro-ject is "just fine". It's just a personal preference thing, it looks cheap.
3db
3db
Yup.
It does look cheap. :eek:
