DENON DN-1200F control software
V
vince138
Does any body know what software is controlling DENON CD changer DN-1200F and where to find it? I spend hours searching internet and I did not found any thing. Please help.:)
2
20to20K
Try this.
Hopefully someone will chime in with the exact info you need. If not you can try this over time. Ebay frequently has this unit for sale. I know because I was considering buying either this one or the DCM-5000/5001 unit at one time.
Whenever I would see it listed, the seller would typically provide a link to the website that sells the software. I've been to the site a couple of times when I would bid on it...but unfortunetely I never saved it.
But my point is what you can do is occasionally search on Ebay to see if someone is selling the unit. If they are, either they may have a link to the controlling s/w website...or at least SHOULD be able to provide it if you ask them. I know it's not an immediate solution, but it's something to try in the interim and perhaps you'll get lucky.
BTW...I just checked and there isn't one out there right now...but there was one last week because I remember seeing it.
Good luck!
V
vince138
Thanks very much for your answer. I come up with this same idea this morning while searching the net. :) There is one unit on eBay but they do not have software for it. I know the software name but the company making it doesn't support it any more. There are to different software controlling this unit. Mac version is Song Servant and Windows is TuneBasic. I'm actually interested in the Windows version. Thanks for your suggestion.
Jack N
I too have been looking for this software for over a year. I check eBay and Audiogon every day. Please let me know if you find a copy somewhere.
G
gman007
Any updates???
I'm also still looking for the software........any luck?
maree walker
denon dn-1200f 200 disc changer
Good luck!
I have a denon dn-1200f disc changer i am letting go really cheap,i dont know too much about this equipment but all i know is my ex-husband paid over 3,000.00 for it .it is still in box.714-366-3207
