I just bought and started using my new 790, and right now I have a couple of problems. I tried searching the forums but didn't see anything.
One problem is lip sync with the TV. I know I can just mute the TV, but for some reason I like hearing it all. Although I'm waiting for a new TV to be delivered Monday, I'm thinking it will likely have the same issue. I have the 790's delay set to 0, but I can hear the TV's audio a hair before the fronts (3.1). The TV is a 32" Toshiba Regza LCD, still fairly new as it only came out a couple of years ago, and I can't find anything about delaying its sound. The signal from the TV is going to the receiver via Toslink. Didn't have this problem with my 15 year old receiver and this TV, though the connection was with rgb cables. The new TV will be a 42" Panasonic plasma G10 series.
Another problem is with video upscaling. The 790 should be able to upscale everything to 1080p, and do it well according to a review I read. But last night I streamed a video from Netflix, which should mean that the receiver is getting it at 720p, but when I check the TV, it's still at 720p. So it's acting like a pass-through. There must be a setting I'm missing I guess, the manual isn't much help since half the time they assume you have a degree in electronics or something.
Anyway, if someone knows offhand that'd be great. Maybe I just need to look at the manual again. Thanks for any help.
