sharkxii
I just set this up, checked everything. The test for the speakers is fine, but when I play any input the sound is really low and almost no bass.
help!
Adam
Adam
Welcome to the forum!
What are you trying to listen to? CD, DVD, radio, etc.?
What speakers do you have? Do you have a sub, and if so, which model?
Davemcc
Davemcc
When you say the volume is really low, what volume setting are you using. -30 to -15 should be suitable for normal listening.
