Denon AVR-600: how is this unit for me?
mobius80
My friend just gave me his old reciever, the Denon AVR-600. I am replacing my old JVC unit with this as i heard Denon is better rated. I know this reciever (Denon) is older (around 1996), that is fine, its free.
Does anyone know anything about it? Technical specifications, link to its manual? I couldnt find anything on Denon's website, i guess because it's an old model.
Here is 1 review site i found with many mixed reviews: http://www.audioreview.com/amplification/a-v-receivers/Denon/PRD_118890_2718crx.aspx
Does anyone have experience with this reciever at all? Should i use the Denon or keep my old JVC (from 1993).
- my speakers are also old, but they work perfectly (Acoustic Profilers) with 10" Quest sub
Takeereasy
Takeereasy
Can't you compare them both then decide? Those reviews weren't very sceintific to say the least. I don't think there will be a big difference between the two, but you do have the option of trying and finding out.
av-man
av-man
Is the Denon 600 digital? If so then no doubt it is better for theater. i think the brand Denon is better than most.
mobius80
they are both Dolby Prologic, no digital :(
how can i compare them both and decide when i have nothing to compare except the looks? i know nothing about this stuff, and i cant find any spec sheets on either.
av-man
av-man
Sell them both and put the money toward a Digital unit. You will not believe the difference when you watch a DVD.
As far as comparring the two. Give me the model # of the JVC and I'll research it.
Buckeyefan 1
Buckeyefan 1
I think you can rule out the JVC. $25 and it's yours again!
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39786&item=5777364652&rd=1
Are you sure the Denon isn't an AVR1600? I can't find anything on a 600 model.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39793&item=5778259370&rd=1
Here's an AVR 800 for $60.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39793&item=5778708343&rd=1
I think you should put yours on ebay and buy something a little more modern. You can pick up a cheap surround receiver for $150 that is miles above the two you've listed.
mobius80
yes im sure its the AVR-600 :)
hm, ebay eh... kind of a hassle, maybe ill put them in the local paper for 80$ each :D
would i really notice a difference in Dolby Pro Logic and DD5.1 or DTS?
i have no idea what the difference is
i have 2 fronts, 1 center, 2 rears, and 1 sub
dvd player, and xbox
mike67
I think you will IMMEDIATELY appreciate the difference with a new digital amp.Those ancient units woun't do any good in reproducing digital sountrack ;)
hoanglong6642
pls show me your email address, I will send you specifications for this Amplifier.
N.T.Khiem
hoanglong6642
at yahoo com
