Denon AVR-5805 & Blu-Ray
agular
Does anybody know if the external inputs on the Denon AVR-5805 are affected when Audyssey EQ is engaged?
I plan on using a Blu-Ray player with a built in decoder for
Dolby-HD and DTS-HD master. I would connect the player via the 7.1 analog out to the Receiver's inputs.
AVRat
AVRat
It should when the EXT input mode is set to "DSP". pgs 60,61.
agular
Thanks I see this in the owners manual. Will it play unchanged fully uncompressed Hi-Resolution audio with my EQ setup parameters. Or will it down mix the audio?
