K
Kid Kidd
My situation is that I have a Family room already wired for 5.1 surround. I have a TV nook above a gas fireplace and an audio rack in the corner. I took a lightning strike last week and need to replace my TV and 2 Receivers. I also have 5 rooms currently set-up with speakers and volume controls that all terminate at my audio rack in the family room. I had two receivers before. One for the family room TV and surround sound and the other to power all the speakers in the other rooms. I'm looking to replace those two receivers with one. The 3805 seems to make sense as it allows the use of 2 channel for zone two.
I do have two needs though.
One is that I have infrared in the upstairs so I can control the receiver and cd player from the upstairs so I need to be able to program a universal remote to turn on the 3805 and operate zone 2. Can this be done. Can I change sources for zone 2 and / or radio stations, cd's. My last receiver I thought would do this but had a manual switch for zone two. defeats the purpose of the infared, hence the purchase of the second receiver.
The other is I was also told the zone two cannot output digital audio or video. Not a big problem as the speakers in the other rooms are usually just for easy listening or a ballgame. Will I regret that?
Thanks for any input you can lend!
